R12 in R134 system
Old Aug 7, 2007 | 08:32 PM
dsrour's Avatar
Default R12 in R134 system
Can R12 be put in a 134 system? If so would it be worth doing for the better cooling w/ R12. Thanks
Old Aug 7, 2007 | 08:44 PM
89 formula350's Avatar
yes you "could" in the" r134a system" but you would have to remove all the r134a oil to do it right in which case you pretty much need to replace most of the system with new parts. you could run the retrofit synthetic ester oil and run it like that like most people do in retro fit r12 to r134a systems. but you still need to find r134a to r12 fitting that stay on the car and label the system as r12. I don't think they make.
not really worth the trouble. or cost if you want better cooling work on getting more air flow past the condesor if that means more/bigger better fans then do it. making a air dam to direct the air while driving what ever it takes
Old Aug 7, 2007 | 08:46 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
No, R12 IS more efficient per say. R134a systems run at higher pressures to make up for this fact however.
R134a systems also require different lubricants than R12.
R12 uses mineral oil for lubrication. While R134a uses PAG oil (polyalkaline glycol).
Basically the dessicants/oils are not compatible. If they get mixed/contaminated with each other, you'll either have poor or no service.
Old Aug 8, 2007 | 11:14 AM
Oscar Will's Avatar
Don't do it for the above mentioned reasons along with the fact that you'd be wasting VERY expensive R-12 for a poor result. Head pressures would probably be 'way high I'd think.
Old Aug 8, 2007 | 12:12 PM
Cam72aro's Avatar
R12 is just more expensive. A properly desiged and working r134 system will cool just as good as the old r12 systems.
