LSI in 69 Camaro --- A/C mounting problems
I pretty much figured out a good mount today, I just need the crank pulley/grooves to make it in the exact right spot. Can you take a picture of the ATI pulley for me by any chance. A side shot so I can figure out if it's going to work with my F-body accessories.
Yes Side exit would make it alot easier
Lance
Lance
Thanks!
Thanks!
Don
I, too, want to keep the factory orientation. Frankly I don't like the look of having the alternator and A/C compressor splayed out wide with long belts going everywhere. The S&P option might work as it looks like rather than two belts it uses just one. That will gain us about 3/4" (the width of the A/C belt) and it appears that they have it available for both the Camaro and Vette accessories.
I don't know why VA is sending out the rear exit compressors. The Sanden 508 is available, and commonly so, with the side exit. In fact the "body" is the same and the "tailpiece" can be changed for any number of options. You may want to look into swapping out for the side exit in the event you don't clear.
There is perhaps another option. The compressor used by Mike Stielow is a Sanden SD-7. It has a little less capacity but has side exit fittings that are on the body of the compressor. I'm not sure if it is any shorter. VA offers it with their Front Runner set-up.
Keep us posted!
Jeff
I remember reading somewhere that the VA LSI bracket was developed for that Year One LS1 Camaro that was built by BRP.
Don
Next I'll try the S&P brackets that puts the compressor pulley in the same path as all the other accessories. I also am buying a vertical exit compressor. It's only $200 from Summit and it'll make the problem alot smaller. Anybody need a rear exit 508 Sanden..........cheap? This is really starting to suck. It's not like these so called "kits" are cheap or anything............
Did you call Vintage Air and explain the problem? Maybe they would at least give you a break on the price of the new compressor.
Ryan from VA posts on pro-touring.com. You could post there about this problem and see if he responds. He helped me out adapting the Camaro controls in a Firebird.
Don
if this one works Don
What accessories are you running? LS1 F-Body? LS1 Corvette? LS2?
I'm running LS2 Corvette so if you're running LS1 F-body then I'm definely going to have to try the S&P option.
Thx!
Jeff
He also used custom made pulleys that spaced the drive system out enough to clear the frame.
Jeff
I wouldn't give up on those Corvette accessories until I try the side exit compressor.
Don
