5.3 alternator
99-00 Terminal B needs to be connected to IGN power through a resistance source (can be a resistor or light bulb). Wire terminal B to one side of a 470 ohm 1/2 watt resistor and wire the other side to a wire that is hot(+12v) when the ignition switch is in the run position. Or use a light bulb (usually a 194) instead of the resistor. If you use a light bulb it will act like the generator light in a older car.
01-?? See above for terminal B, and these also require a second wire. Hook terminal C to a +12V IGN source (ie the same wire you used for termial B, but terminal C needs to be hooked directly to it, don`t put a resistor or light in line.
On some 2003 and newer 5.3L`s I heard that they have started using 3 wires, but I can`t remember what the 3rd one is for or how to hook it up.
the resistance does two things in this circut.
1,it turnes on the regulator to charge.
2 , when the key is on, but engine not spinning, regulator inside alt. grounds out. if resistor is not in circut, you will burn up regulator,. questions give me a call, steve 909 910 3867
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Bob
