S10 Swap Using Mustang headers Question
But i remember reading somewhere a few years ago when i first started to research the LS1 swap into an S10 that somebody had taken a set of 87-93 mustang fox body headers, cut the ford flange off and with just some minor tweaking welded on an LS1 flange and they fit pretty well, but now i cant seem to find any of that info and just wanted to see if anybody has actually done this and if so how did it work out?
If im way off base with this let me know that too. My only other choice is going to be buying a weld your own set and building my own, because the samdersons just wont allow the 408 to breath up top.
Ive looked at some Ls1 swap headers for the 1st gen camaro, and they look pretty close, i think the hooker super comps for a 93 mustang 302 are the best ones ive seen, but it is alot of work to redo the tubes and weld on a new flange.
Check corral.net for cheap used sets. I got mine for $200 shipped from there.
Part # on the flanges is 12480130 at gmpartsdirect.com.
It is VERY easy. Cut the Ford flanges off right at the tube, beat the primary tubes back to round, slide the LS1 flanges on the tubes about 3/4 of the way and weld the inside of the flange to the tube. Clean up the weld and off you go!
Good luck!
Jesse
