6L80E Swap
Old Sep 25, 2007 | 04:16 AM
  #41
VictionOne's Avatar
Anyone know the PN for the 6L90e? Heres the PN for the 6L80e...
6L80e - PN 12491349
Old Sep 25, 2007 | 07:53 PM
  #42
Bo185's Avatar
Originally Posted by VictionOne
C6's run this transmission and people say it is a MUCH better transmission than the old 4L60e. I've been told that it doesnt shift like a traditional transmission (ie. 1>2>3>4.. etc) but can shift from 2nd to 4th, 6th to 1st, etc.
Some info on shifting
Originally Posted by James B.
The 6L80-E is a clutch-to-clutch transmission. That means that the gear it's in, no matter what, will feel like engine braking if you lift the throttle quickly because there are no freewheeling mechanisms. Despite having 2 more gears, the 6L80-E is more mechanically simple than the 4L80-E.
If you have ever driven a 5 or 6 speed Allison 1000 you know how shifty those are under certain driving conditions. The Allison is clutch-to-clutch also. The 6L80-E takes some getting used to just as the Allison does.
Old Sep 25, 2007 | 09:42 PM
  #43
philntx's Avatar
Hey Vic,
The 6L80E shifts just like the 4L65E, 1>2>3>4>5>6. Unless you command it to start in second.
- Clutch-to-clutch shifting
- Wide 6:1 gear ratio spread; steep 4.03:1 first gear for improved launch and acceleration
- Two overdrive gears for reduced revs at highway speed – 0.85:1 in fifth and 0.67:1 in sixth
- Rigid aluminium case for low noise transfer to the vehicle and high torque capacity.
- Performance mode detects sporty driving and holds gears rather than allowing upshifts
- 32-bit electro-hydraulic control module
Old Oct 18, 2007 | 03:30 PM
  #44
Gen3Benz's Avatar
Found this article....
GM automatic transmissions
6L90 max gearbox torque....885!
only weighs 240lbs
Old Oct 18, 2007 | 03:58 PM
  #45
mmmchickenboy's Avatar
Originally Posted by Post #14 of this thread
6L90E:
Maximum engine torque: 531 lb-ft
Maximum gearbox torque: 885 lb-ft
The values on GMI are misleading.
Old Oct 18, 2007 | 04:56 PM
  #46
'JustDreamin''s Avatar
GM seems to have rated their HD transmissions for max gearbox torque of 885 ft-lbs (4L80E / 85E & 6L90E)....
GM Powertrains' website has a bunch more info, I'd trust it more than GMI's info.
Here's some data from it:
4L60E Max Eng Tq = 360 ft lbs, Max Gearbox Tq = 610 ft lbs
4L70E Max Eng Tq = 400 ft lbs, Max Gearbox Tq = 670 ft lbs
4L80E Max Eng Tq = 440 ft lbs, Max Gearbox Tq = 885 ft lbs
4L85E Max Eng Tq = 460 ft lbs, Max Gearbox Tq = 885 ft lbs
6L80E Max Eng Tq = 439 ft lbs, Max Eng Pwr = 469 hp, Max Gearbox Tq = 664 ft lbs
6L90E Max Eng Tq = 531 ft lbs, Max Eng Pwr = 452 hp, Max Gearbox Tq = 885 ft lbs
Allison 1000 Max Eng Tq = 660 ft lbs, Max Eng Pwr = 365hp
Allison 2200 & 2350 Max Eng Tq = 565 to 660 ft lbs, Max Eng Pwr = 300 to 340hp, depending upon application.
An interesting side note is that the 4L80E is used behind the Duramax in van applications, but its derated to 250hp / 460 ft lbs tq because the trans isn't rated for more (trucks running Allisons are rated at 365hp / 660 ft lbs).
On topic, I find it interesting that the 6L80E is rated for more power but less tq than the 6L90E, but the gear ratios are the same (best as I can find). Funny, huh...
'JustDreamin'
Old Oct 1, 2008 | 03:24 PM
  #47
1BadAction's Avatar
So, when can we buy the harness for an 07 and up trailblazer SS?
Old Mar 12, 2009 | 11:51 AM
  #48
evo45's Avatar
I know this is an old thread but do we have an answer to this? I'm intrested too!!!
Old Mar 12, 2009 | 11:57 AM
  #49
1BadAction's Avatar
I am still waiting, cash in hand. Seems like with alot of these companies, if you arent wearing a gold chain and sporting a corvette logo, or willing to hack up a nice vehicle, you gotta fight tooth and nail to get anything done.
Old Nov 19, 2010 | 12:47 PM
  #50
LS1MonteSS's Avatar
I'm working up a 6L90E swap for my 70 MC.. The tranny tunnel in most cars starts getting tight at the TH400 size.. I have been searching for someone who has done the swap into a "A" body car..
Old Nov 19, 2010 | 02:34 PM
  #51
Jones'n's Avatar
Check here:
http://www.355nation.net/forum/engin...wer-6l80e.html
and here:
http://tbssowners.com/forums/showthr...=28946&page=24
Old Dec 12, 2010 | 08:06 PM
  #52
48Ripper's Avatar
Looking for a 2wd output shaft and tailpiece. I have a 4wd 6L90e and want to convert to 2wd. Any help locating part would help. Thx
Old Jan 19, 2011 | 10:36 PM
  #53
prerun400hp's Avatar
i second this info needed except for the 6l80e
Old Sep 9, 2011 | 02:08 AM
  #54
thehpw's Avatar
Interesting, if I swap the LSX/6L80E combo onto my 68 camaro Im looking at less 150lbs for the engine but plus 100 lbs for the tranny (current TH350 weighs 125 lbs vs 230 lbs for the 6L80E). Damn, I was really hoping to make the car lighter by going with the all alum engine. At least the weight is farther back I guess. : )
Old Sep 29, 2011 | 04:05 AM
  #55
TrueBlueGTO's Avatar
Further back, lower center of gravity, and it'll keep your engine in a narrower torque band.
