Will 94 p.up speedometer work with ls1 vss signal?
I have all the gauges including tack working but have been stymied so far in getting speedometer to function. The stock speedometer works off a similar pickup device in trans but I am not able to get it to function with the feed from the pcm. Any suggestions or past experience would be appreciated? Thank you. Chuck
9 Second Club/LS1TECH Sponsor
Yes, it will work perfectly. You have to make sure the LS1 PCM output is going straight to the Speedo and not thru the DRAC module. You want the line OUT of the DRAC module that goes to the speedo.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
