Need Help. Ls7 clutch wont disengage.
I have a LS2 engine in a 86 iroc. I am using the ls7 clutch setup. I have new slave cylinder and clutch master cylinder. I have bleed the clutch and still wont disengage. THe pedal still doesnt feel right. I can push the clutch in with the car in gear and the car jumps like the clutch is not pushed in. I am using 4th gen pedals. Any suggestions on what to do.
this might sound dumb but a GM dealership told me to hook everything up and pump the pedal about 120 times then it would be ready to go. Sure enough it worked. after about 80 pumps the throwout bearing finally started working properly. Maybe give that a shot.
