4L80E Range switches, remove them?
Old Sep 19, 2007 | 03:28 PM
ryanvv355's Avatar
Default 4L80E Range switches, remove them?
Can it be done in a stand alone swap or do i need to keep them? I'm working on the harness right now and need some insight. Thanks.
Old Sep 20, 2007 | 07:20 AM
ryanvv355's Avatar
Anyone?
Old Sep 20, 2007 | 08:31 AM
01WS6/tamu's Avatar
The range switches are internal to the transmission. The box on the side is only for the pn switch and gear shift indicator.
Old Sep 20, 2007 | 09:06 AM
ryanvv355's Avatar
O, well thats what i mean then, can i take them off and de-pin the PCM connector accordingly?
Old Sep 20, 2007 | 10:38 AM
jeepinpete's Avatar
The PCM needs pretty much every wire going to the trans...
Old Sep 20, 2007 | 12:55 PM
01WS6/tamu's Avatar
The box on the side of the transmission yes. It is the pn switch, back up lights etc. It will function wo it and not effect the transmissions ability to shift.
Old Sep 20, 2007 | 01:25 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
The other function of the box on the side of the trans is to send signals to the PCM that lights up the the "P R N D L" on the instrument cluster. You won't need any of that for a swap.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Sep 20, 2007 | 02:11 PM
ryanvv355's Avatar
Cool, there gone then, thanks guys!
