Alternator mounting problems
Old Sep 25, 2007 | 11:48 PM
55LS1's Avatar
Default Alternator mounting problems
I'm making alot of progress on my 55 LS1 conversion, but just got stuck with the alternator! I'm running an electric water pump with a S&P cylinder head bracket. The problem is the belt hits the bottom of the electric motor on the water pump. I'm not sure what to do with this setup, does anyone have any ideas or input? Any advice or information is greatly appreciated!
Attached Thumbnails Alternator mounting problems-img_0809.jpg   Alternator mounting problems-img_0810.jpg
Old Sep 26, 2007 | 03:42 AM
LSInnovations's Avatar
Why not move the alternator down low and tight to the block??
you can bolt one side straight to the block with a short round stock spacer piece (I can give you the exact measurement if you need it). 30 seconds cutting a piece off a stick of round stock....
Other side use a standard two ended heim joint attached from the block to the alternator for tensioning and adjustment...
Old Sep 26, 2007 | 05:07 AM
forcd ind's Avatar
call s&p and talk to mark-he can prob come up with something-maybe an idler pulley to lower the belt away from the pump, might be able to attach it to one of the alt bracket bolts
Old Sep 26, 2007 | 12:01 PM
55LS1's Avatar
Do you have a pic of that setup? I have a stock f-body bracket, but the frame on the 55 doesn't allow me to use it.
Old Sep 26, 2007 | 05:13 PM
FirstGen's Avatar
I would add an idler pulley, that would be the easiest thing...
Old Sep 28, 2007 | 03:09 PM
55LS1's Avatar
Its B.S. that you can't get an alternator bracket for around $200 that works with this setup. I grew up on SBC's and there is no way it should cost $550 for a freakin LS1 alt bracket! (A little pissed right now) I'm guessing I have to go back to the stock WP to make this work.
Old Sep 28, 2007 | 03:43 PM
RE AND CHERYL's Avatar
How about a power pulley. It would be smaller in diameter.
Re'
Old Sep 28, 2007 | 08:47 PM
Armen, PM me your email address and ill send you some pics of how I did mine on my mustang...
It doesnt take a bracket, just $20 in parts. Ive got the same WP as you with similar setup
