Identifying a LQ9......hopefully not a LQ4.
Old Mar 8, 2016 | 12:31 PM
  #41
75chevyboy's Avatar
Default can u identify this engine
Originally Posted by 69LT1Bird
The book is wrong. They all are have throttle by wire from 2003 till today. Sorry. If you can find the VIN in the engine I can run it and let you know what is from. I have a 2002 LQ4 that has a cable, 2003 went to throttle by wire in the trucks. PM me the VIN if you have it.
(1GYEK63NX3R263522)
Old Mar 8, 2016 | 12:37 PM
  #42
93Z2871805's Avatar
Veteran: Air Force
Originally Posted by 75chevyboy
2003 Escalade. It's an LQ9.
Old Mar 8, 2016 | 03:12 PM
  #43
64post's Avatar
LQ4 could have an issue with T56 bolting up to it due to the thick crank flange, not sure about the LQ9. Pull a plug and look into the cyl with a borescope and you'll know for sure what you have.
Old Mar 8, 2016 | 09:20 PM
  #44
tfi racing's Avatar
Only an issue with the 99-2000 iron head 6.0,after that the only difference is the dished piston in the LQ4.
Old Mar 9, 2016 | 07:51 AM
  #45
truckdoug's Avatar
i never needed a borescope to check piston dish if the engine is out of the vehicle. i use one of these and stick my eyeball down there next to it.
https://www.zoro.com/streamlight-ind...Q&gclsrc=aw.ds
with 15* valve heads it's pretty easy to see the piston at TDC
Old Mar 9, 2016 | 08:30 AM
  #46
runsfromdacops's Avatar
i thought lq4 had iron heads and the built in crank spacer
Old Mar 10, 2016 | 08:10 AM
  #47
truckdoug's Avatar
yup, its true. better leave them alone and just look for lq9's
Old Mar 10, 2016 | 04:42 PM
  #48
TJ's Avatar
TJ
only 99 and early 2000s if its a factory untouched aluminum head, you have no worries with the crank, you can just remove the spacer
Old Mar 10, 2016 | 06:35 PM
  #49
69-chvl's Avatar
If you drop the pan and look at the rods and find them to be of the floating variety, its a good chance its an LQ9. All LQ9's had the floaters...at least my 02 LQ9 does.
Old Mar 10, 2016 | 10:10 PM
  #50
truckdoug's Avatar
i can't tell if they're floaters unless i look at the side of the piston
Old Nov 15, 2021 | 07:12 AM
  #51
elfgoat's Avatar
What if you just have a raw block with only 6.0 engraved and a
Only identifying numbers on the block….LQ4 or LQ9
Old Nov 15, 2021 | 08:39 AM
  #52
Alwhite00's Avatar
Bore scope if you can't tell through the plug hole.
Old Nov 15, 2021 | 10:48 AM
  #53
LQ9 and LQ4 use the same block. The difference is in the innards.....
Old Nov 15, 2021 | 10:49 AM
  #54
elfgoat's Avatar
Appreciate it guys. Just trying to get her to 600HP mark N/A
Old Nov 15, 2021 | 10:51 AM
  #55
He has a bare block. Sooo.... ????
Old Nov 22, 2021 | 08:03 PM
  #56
Smitty454's Avatar
Originally Posted by cobalt964
99-02 6.0 were dbc, 03-newer dbw, except 03-04 3500 vans still dbc. I have seen lq4 and lq9's with 317's. only way to differentiate is pistons.
My 2002 LQ9 is drive by wire.
