PCM issue w/convertion
Old Oct 10, 2007 | 10:56 PM
gonzo 6.2's Avatar
Default PCM issue w/convertion
Not sure if this is the place to ask but lets see what comes of this.1992 K15 swapped in a 6.0 The cooling fans are set to come on at 199,the PCM fan 1 wire gounds at that temp but flashs on and off.fan 2 is set for 205 it never grounds.
I ran the test light to the batt + the other end to the fan wire for test.
A constant on/off WTF help please THANKS
Cant be in the EFI live???
__________________
Old Oct 10, 2007 | 11:24 PM
G-Body's Avatar
sawzall wielding director
Sounds like the on/off temperatures are too close.
If you have EFI Live/HPT go into the fans section, if the on setting is 199 set the turn off temp to 189.
350SS's Avatar
is {G1203} set to Series Parrallel Fans?
Old Oct 11, 2007 | 09:15 AM
gonzo 6.2's Avatar
I had mistakenly had AUX. I will reflash it with parrallel.
I will report back either way
Old Oct 11, 2007 | 11:53 AM
gonzo 6.2's Avatar
Well hell,no difference.When it reaches 199 as its set to it consisantly is on/off and fan 2 never will ground.I looked and relooked at EFI live there very well could be something i missed I just dont know.The PCM is 00 truck harness is Fbody 99.reworked by a discount sponsor
Old Oct 11, 2007 | 12:40 PM
350SS's Avatar
did you try to force the fans on using the bidirectional controls?
Old Oct 11, 2007 | 01:03 PM
gonzo 6.2's Avatar
Great idea I will and report back!
Old Oct 11, 2007 | 01:55 PM
gonzo 6.2's Avatar
OK with the brain power here i know you guys can help.I am new at this EFI live so I dont pretend to know anything.
If i command high speed then my marked as # 2 fan blinks (it never did anything before) I hit low speed fan #1 stays steady like it should.
Maybe I dont understand whats going on or supposed to go on with high/low fans when I see #1 and #2 fans marked wires.
And to recap.The #1 fan blicks when the engine temp get to 199
My test light is hooked to 12v and light when grounded by PCM THANKS TO ALL
