Where to get trashed LS1 for fabricating?
Old Nov 25, 2007 | 09:35 PM
cdoggy81's Avatar
"You can also use a block and heads from a truck motor, 4.8, 5.3 or 6.0. They all have the same dimensions, bolt holes, and the parts are all interchangeable with the LS1. Only difference is the block is iron instead of aluminum. Used 4.8's, are EASY to come by nobody wants them."
What years? I'll keep my eyes open for one too!
Dogger,
I sent you a PM about your block.
Old Nov 26, 2007 | 07:55 PM
70 chevelle's Avatar
Found my cracked ls1 block on craigslist for 50.00. If you can find a cracked aluminum block cheap it's worth that much as scrap afterward.
Old Nov 26, 2007 | 08:06 PM
Jake@EPP's Avatar
You say your in Michigan, i have a few dead ones here. I would take $50 if you came and got it. Im in Columbia City, around ft wayne IN.
