clutch connector
Old Oct 23, 2007 | 07:09 PM
SPG's Avatar
SPG
Default clutch connector
im swapping a t56 into a project car. i need to find a source for a gm type snap connector to the hydraulic clutch tob
i could cut the end off a stock one and attac it to another length of hydraulic hose,but want to see if i can find a source of a part
any suggestions??
Old Oct 23, 2007 | 08:06 PM
LS1MCSS's Avatar
All I can say is good luck. I had to buy a complete master cylinder, with line, just because I had a broken line at the connector. I couldn't find just the line anywhere.
Old Oct 23, 2007 | 08:22 PM
djquik88's Avatar
What I used was a Russell part # 640281 fitting that I bought from Summit.They come in a pack of 2 so you can use one on both the SC and the MS end of the line. I also used a -3 an Earl's Teflon lined brake line. I think the total was about $35-$38 to go this route.
Old Oct 23, 2007 | 09:18 PM
Schitzo's Avatar
Theres many ways to skin this cat.
1. Use the fitting below.
Part# MCL-139026
2. Mcleod sells a ss line with the fitting on one end. These are usually on back order.See pic below.
Summit part # MCL-139204-23
Jegs part # 673-139204-03
3.Buy a used master cylinder, take it to a hydraulic shop and have them crimp the fitting to the hose you want.(cheap and actually works)
Old Oct 24, 2007 | 10:06 AM
Hugger Z's Avatar
Do a search in the manual transmission section. I remember reading that someone took off that snap-in fitting and replaced it with an AN type fitting that they had crimped to the hose.
Old Oct 25, 2007 | 09:46 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
http://carshop.carshopinc.com/produc...ssell%20640281
Old Oct 25, 2007 | 02:58 PM
SPG's Avatar
SPG
thanks guys, a few options there.
posted a message in the WTB section, if no response ill buy a connector from carshop.
