What is the purpose for a fuel sump?
You need a sump so that fuel stays near the pickup under cornering, accleration, braking, etc. Without it, yes, your fuel supply will be interrupted at some point.
It's like using an oil pan without baffles or trap doors.
Unless one pump has some magic fuel magnet in it, fuel will drift whichever way the car does. Sumps are like a reserve mini tank for the pickup.
Not running one is akin to using a lighter to see in a gas tank.
Every factory car with EFI, EVERY SINGLE ONE, has one. Its not because they like spending more building a car than they have to...
Any smart drag racer uses one as well, including myself in my old 10.09 3400lb GTO...
Once you get a fast drag car with a carb, that millisecond that you will lose fuel will be enough to drain your bowls and lean out the motor.
You have to remember how much force there is pushing that fuel towards the back of the car when you're going down the track. One millisecond of the pump going dry will drain your bowls out for sure.
So you can get away with it with a slow car as long as your tank remains full to a certain level. Once you start going fast, you're all done.
