A few LS1 fuel system questions
Will this filter work ok for my ls1 swap? It will be with a walbro pump and aeromotive regulator. Will it work ok under high pressure? Will it work better before or after the pump?
By the way....whats the best fitting to go from -6 aluminum tubing to braided hose?? Link??
The walbro pump came with slip on/clamp fittings with copper washers. Does earls make AN style fittings for this. I would like to hard line as much as I can. Thanks.
Only thing different about the LS1 than other EFI motors is the increased pressure.... Looks like that one is right on the edge of being safe ratings wise.
Of course, you'll need to calculate the gallons per minute to make sure it will flow enough to support the BSFC of your motor. That's the key.
Universal Yes
Fuel Type Gasoline
Fuel Delivery Carburetor
I would not use it. They list it for carb use so I assume it isn't recomended for high pressure.
Re'
I used this one. The one you listed had a micron rating of 85. That is more of a screen instead of a filter.
Be OK for street duty. No GPM rating listed...
http://www.filtercouncil.org/techdata/tsbs/89-5R3.pdf
The local speed shop got me this one but they say it is not a popular fitting. Is there something I am missing? Is this the fitting, combined with a flare-nut-sleeve, to connect to my stock lines coming from my tank? Thanks
On a side note, you really shouldn't be using aluminum for hard lines due to fatigue problems--use stainless.
