LS1 Into A 93 Chevy 1500
Old Nov 4, 2007 | 09:13 AM
black_dragon_93's Avatar
Default LS1 Into A 93 Chevy 1500
ok i have already read the info on this swap but with a 5.3, i wanna swap a ls1 into my 93 1500 that has a 4.3 tbi, i have A/C but i dont really care if i keep it or not, i need to knwo what kind of harness i need along wiht brakets ETC and also how the hell would i hook this up to a dash, i plan on running all custom auto meter gauges if that helps also the truck is an auto
Old Nov 4, 2007 | 03:05 PM
LS1GMCTruck's Avatar
Default LS1 Into 1500
The LS1 engine harness & computer simply need to be mailed out & converted to a "stand-alone" harness/computer programming. When you get it back, there are only a few wires that you hook up & it will start right up. The mount plates that bolt to the engine are available on E-bay, as well as other sources, such as S & P(Street & Performance). Everything you need to know to accomplish this swap is available in the sticky section at the top. It does require a bit of research on this site to answer all your questions, but it is ALL there. Research, research, research...
