LSX oil pans
http://www.powerbyace.com/Technical%...20P%20mods.htm
Accompanying mounts and headers are available
http://www.powerbyace.com/index.htm
Word to Holley...when I installed the pan, I elected to bolt the bellhousing to the motor and then bolt the pan up. This proved to be a wise idea because when I removed the bell I noticed that the pan was not flush with the back of the block surface. Also, I used the Holley o-ring only because the factory o-ring was thicker and it appeared that this may take more effort with the oil pump screw to tighten. I would suggest modifying your pickup tube to accept the factory o-ring and the factory hardware. The GM oring is more pliable and the factory hardware is longer. Also...your trap door assembly for the 302-1 pan does not fit. I had to trim about 1/8" off the bottom of it so that it would fit.
Has an type of pan with 4.5" depth come out yet from anybody? The batwing pan will not fit between the frame rails unfortunately as it looks to be about 1/4" shorter.
Any help is appreciated.
Russ Kemp
Russ Kemp
Russ kemp
https://ls1tech.com/forums/conversio...d-i-score.html
http://www.chevelles.com/forums/showthread.php?t=717386
