V6 to ls1
Old Nov 22, 2007 | 04:43 PM
rumblebox's Avatar
just buy an ls1 car. i got mine for $7k and it has leather and T tops. good deals are out there. just keep your eye open.
Old Nov 22, 2007 | 05:43 PM
Coonass350's Avatar
okay well im not sure if i wanna buy one with an ls1 or if i want to get one with a V6 and swap it out with a 6.0
Old Nov 26, 2007 | 02:01 PM
rumblebox's Avatar
get one with an LS1 and swap in a 6.0. much easier and still more cost effective.
Old Nov 26, 2007 | 06:31 PM
Coonass350's Avatar
okay well i will try to find one with an ls1, a friend of mine told me that if i got a formula instead of a ws6 or something it would be cheaper on insurance. is that true?? and how hard would it be to swap the ls1 out for a 6.0?
Old Nov 27, 2007 | 01:21 PM
rumblebox's Avatar
i dont know if it had to do with the year model or what, but my 99 formula is 50 bucks cheaper per month than the 2000 trans am i had.
Old Nov 27, 2007 | 01:22 PM
rumblebox's Avatar
and a 6.0 is a direct swap for an LS1, but the truck intake wont fit under the F body hood. if it's a 01/02 use the intake that was on it. if its a 98-00, get an LS6 intake or F.A.S.T. intake.
Old Nov 27, 2007 | 08:38 PM
Coonass350's Avatar
oh okay man thanks i appreciate all the help, so around how much is your trans am a month on insurance?? if you dont mind me asking.
Old Nov 27, 2007 | 09:25 PM
RE AND CHERYL's Avatar
Insurance prices vary wildly from person to person, state to state and depending on age and driving record. Call your agent.
Re'
Old Nov 27, 2007 | 10:08 PM
95GreenZ28's Avatar
Sorry for the late response. Cleaance is perfect if you use the lt1 style air intake.
Old Nov 28, 2007 | 07:13 AM
blackbyrd's Avatar
im in the process of convering my 2001 firebird v6 to a 414 6.0liter based motor and i can tell you right now buy the ls1 car and swap it, i kept mine cause i have a lot of stuff done to it as is and didnt want to loose all of that and start over. getting the motor in is not the hard part the only thing that has to change for it to work is the k member and an ls1 steering rack (v6 one will hit the alt since its mounted lowside) but the wiring aspect of it is quite indepth for any average mechanic and that is on a car built for the ls1, these guys are right you will spend more trying to make one work then getting one that it will work in to begin with
Old Nov 28, 2007 | 11:35 AM
Coonass350's Avatar
blackbyrd, thanks for the comment, i was looking for someone to reply and tell me that it was hard lol, so i think i will just try to find an ls1 car and then just start from there, first off im not that good with the wiring ****, and second it sounds like alot more than i thought swapping the V6 for an ls1 so thanks for all the help guys, i appreciate it.
Old Nov 28, 2007 | 12:10 PM
  #32
rumblebox's Avatar
the TA was 175 and the formy is 120. same agent...... and i'm under 25. lol
Old Nov 28, 2007 | 12:47 PM
  #33
blackbyrd's Avatar
well if you were just gonna put an ls1 in a 98 and up v6 car it wouldnt be as bad i had one guy tell me that if you put the same year pcm and harness in it, its all plug and play that way. but i am not for sure on that one. but if you want to do the 6.0 there is a lot of complementing mods you have to do. you will have to upgrade front shocks to account for the added wieght of the iron block, stronger tranny and rear end to account for the power, bigger injectors and upgraded fuel system. its a lot of nit picky **** that adds up to big money.
Old Nov 28, 2007 | 04:45 PM
  #34
Coonass350's Avatar
oh okay, i didnt realize it was that much added **** you had to do for the 6.0.
Old Nov 30, 2007 | 07:35 PM
  #35
yannickleprince's Avatar
me too wanna swap my v6 into an LS1. I bought a 91 camaro for around 750 but the tranny is dead. is it gonna be a lot of headaches, tears, sleepless time and money consumming? where should I start? I am not great in performance
