Not seeing any IAC counts in Atap
Old Jun 20, 2003 | 07:44 PM
86MonteSSLS-1's Avatar
Default Not seeing any IAC counts in Atap
Not seeing any IAC counts in Atap v2.04 Can see everything else. Replaced IAC valve with new one still nothing, Any Ideas?
Old Jun 20, 2003 | 08:15 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: Not seeing any IAC counts in Atap
Do you mean the count is zero, or that it's not being displayed?
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jun 20, 2003 | 08:17 PM
reads zero all the time
Old Jun 20, 2003 | 08:22 PM
Speartech's Avatar
Vacuum leak.
Throttle blade hole drilled too big.
Throttle blade screw turned in too far.
Is your TPS voltage in the .6 -.7 range?
__________________
www.speartech.com
Old Jun 20, 2003 | 08:32 PM
.5 engine not running
TB screw backed out
Hole ? could be
No leaks
