Lt1 2 Ls1!
Old Nov 25, 2007 | 08:58 PM
MeanGreen's Avatar
Default Lt1 2 Ls1!
A friend of mine has a 1994 Firebird Formula that he wants to change over the LT1 to an LS1. He already found an LS1 motor minus the electronics. Will the 4L60E he has right now bolt right up to the LS1 along with the converter? What else would he need to convert this LT1 to an LS1? Any help would be appreciated.
Old Nov 25, 2007 | 09:22 PM
RE AND CHERYL's Avatar
It will bolt up but would require a custom converter to boly up to the LS1 flexplate. To my knowledge this isn't available because it's easier to just use a LSX 4L60E.
Re'
Old Nov 27, 2007 | 08:09 AM
formula17's Avatar
Default trans
Yes you can use it, you need a different flexplate and spacer kit and you can run the same converter.
Old Nov 27, 2007 | 09:22 AM
95GreenZ28's Avatar
He will also need ls1 kmember, steering rack, fuel lines or use 97 vette fuel rail, etc
