Custom Aluminum gas tank info
I have swapped a LS2 motor in my 69 camaro and when looking for a tank I found a guy locally that built one for me. I thought I would share the info. It is a custom built tank built to factory dimensions with a sump added for the pump to sit in. It is fully baffled and fit in the stock location using the stock straps. I ordered the Tanks Inc walbro pump and a sending unit for the gauge and took them to him. I couldn't be happier with his work and the look and fit of the tank. A tank contoured like mine with all the angles cost around $500. He will need your stock tank or a detailed drawing with measurments along with the pump you want to use or he can supply a GM pump. I will add a few pictures of my tank.His main business is building aluminum radiators.
Contact info: Tapp Inc. Located in Sophia, NC #336-861-9284
http://s271.photobucket.com/albums/jj125/nc69rs/
