Another 4L60E question
Old Jun 25, 2003 | 04:00 PM
68ragtopLS1's Avatar
Default Another 4L60E question
For the lines going to the cooler, which one is pumping fluid out and which is the return? Right now I have the top line on the radiator going to the top fitting in the tranny. I'm not sure if it is right. Thanks, John
Old Jun 28, 2003 | 10:05 AM
Rod G's Avatar
Default Re: Another 4L60E question
The top fitting on the trans. supplies fluid to the cooler and the bottom fitting is the return from the cooler so you should be fine.
Old Jun 29, 2003 | 07:43 PM
Thanks Rod.
