ls1 swap in s-10
Old Dec 12, 2007 | 09:08 AM
realslow94z28's Avatar
Default ls1 swap in s-10
having a hard time starting engine, i have spark and fuel pressure at regulator, and i measured voltage across injetor connecter w/ key switch on and i get 6.5 volts, when engine turns over voltage drops to 4.9 to 5.5 volts is this normal?
Old Dec 12, 2007 | 09:25 AM
andrew69_04's Avatar
how much fuel pressure do you have?
Old Dec 12, 2007 | 10:30 AM
When Key Is On Fp Is @ 62psi Then Drops To About 55psi.
Old Dec 13, 2007 | 08:58 AM
so does it actually start? or is it trying to start, but wont?
Old Dec 13, 2007 | 09:49 AM
01WS6/tamu's Avatar
Your fuel pressure is fine. You need to check to see if you have spark, then get a noid light to see if you have injector pulses. However one point of concern may be the voltage you were mentioning at the injectors. Is that reading being taken by reading between the two wires at the inj connector while you are cranking it over or is it KOEO. IF that is how you are doing that may be why you are getting the voltage readings you are. Turn the key on and test the pink wire at the injector connector with a test light to verify you have 12 V. Then use a multimeter to determine exactly how much power is ther voltage wise. Check that post it all back here and we'll see if we can work you through it. Do you have access to a scanner to check crank rpm while the motor is spinning over and to get at other data. It would start and die if the VATS was the problem but did you have the VATS tuned out. Good luck
