Chevlle gas tank ?
Old Dec 14, 2007 | 02:17 PM
bczee's Avatar
I am also using a 95' Impala tank with a Racetronix/Walbro pump and wiring kit. I make a access panel above the tanks sending unit to clear and give me access should I needed it (and I did two month able when the electrical ground came loose in the tank.)
It does hang done a bit lower, but it has not given me any problem over any speed bumps over the past year that I have been run.
Old Dec 14, 2007 | 07:26 PM
G-Body's Avatar
sawzall wielding director
I just checked the caddy fuel sending unit/pump/bucket that I have and the maximum extended tank depth is 9.75" but it can sit in a tank as shallow as 8"
Old Dec 14, 2007 | 07:44 PM
oange ss's Avatar
i think my tank is only 6" deep at the most.....have a part number for the setup ?
