LSx pullout What is needed?
Old Dec 13, 2007 | 07:08 PM
86SS86LS's Avatar
Default LSx pullout What is needed?
I am looking at getting a 4.8/4L60E from a 2000 GMC 1500 2WD. Obviously I need all accessories, MAF sensor, wiring harness, pcm, gas pedal and linkage. Is there anything needed for the swap that is easy to overlook? The guy I am buying it from has it in a running pickup, so everything is there but I don't want to forget anything and have to buy it later on.
Thanks in advance.
Old Dec 13, 2007 | 07:44 PM
cherryelky305's Avatar
o2 sensors, cats if your running em', off the top of my head.
Old Dec 13, 2007 | 10:08 PM
SirWarrior's Avatar
here's a great start for a LSx swap that I found
Covers Auto and manual trannies and shows locations of everything.
http://www.hotrodlane.cc/PDFFILES/ls...nessSquire.pdf
Old Dec 13, 2007 | 11:47 PM
G-Body's Avatar
sawzall wielding director
I`ll try to remember to post stuff up as I think of it, but for now...
Underhood fuse box and a couple feet of wire after the connectors
OBD II plug under the dash
fuel pump/sender if you want to reuse it.
The air intake tract may be helpful depending on your swap.
don`t cut the radiator hoses, take them whole you ca reuse um or at least have them to test fit with.
Old Dec 22, 2007 | 08:42 AM
86SS86LS's Avatar
Do the LS1 and truck motor exhaust manifolds use the same exhaust flange? I plan on using f-body manifolds, but the pair that I've located do not have the flanges. If the 4.8 flanges will work it will be one less thing to buy.
