'06 LQ9 - Cruise Control w/ETC - Indicator
Old 12-24-2007, 04:00 PM
TomH's Avatar
Default '06 LQ9 - Cruise Control w/ETC - Indicator
Greetings!
How are you getting an ENGAGED indication on your Cruise Control with an '06 LQ9 (Gen III 6.0L) using ETC?
Many thanks!
Old 12-25-2007, 08:31 PM
eagleuh1's Avatar
Default engaged?
My car usually just goes the same speed I set it at, with foot off accelerator pedal. Pretty good indication its engaged! LOL, sorry, couldn't resist. Are you asking about like a dash light indication or something?
Old 12-25-2007, 11:21 PM
TomH's Avatar
I have a lonely LED that is looking for love.
Old 12-26-2007, 10:34 AM
01WS6/tamu's Avatar
The cruise engaged signal(lamp) is derived from serial data sent to the instrument cluster via the pcm and TAC module.
Old 12-26-2007, 10:43 AM
TomH's Avatar
I'd like to buy a vowel... (I'm not using an OE instrument cluster.)
What would I read from the PCM (i.e. What pins) and the TAC to create the trigger?
Thanks.
Old 12-26-2007, 10:54 AM
01WS6/tamu's Avatar
There is not a way to reproduce the engaged signal. When that signal is sent to the pcm and the instrument cluster it is a digital signal sent over the databus. The pcm nor the tac module send out an analog signal when the cruise sets. The only way as such you could do it but it is not accurate, is to tap the gray wire from the cruise stalk. However, the indicator will then light anytime the slider on the cruise stalk is in the on position. But this will not be entirely accurate because the indicator will then be on regardless of whether cruise is actually set and holding a road speed or it is off.
Old 12-26-2007, 01:11 PM
TomH's Avatar
I am thinking that I can build a circuit like this one from the 12V Guy. The idea would be to use the input from the Cruise On as the power (Red) feed and the Set/Accel and Coast/Resume switches (With diodes) to serve as the (Green) trigger. By tying the brake switch into the ground on the second (right side) relay, I can interrupt the ground (Black) circuit and turn off the light.
http://www.the12volt.com/relays/page5.asp
Attached Thumbnails '06 LQ9 - Cruise Control w/ETC - Indicator-momentconstant.gif
Quick Reply: '06 LQ9 - Cruise Control w/ETC - Indicator
