LS1 in a C3 fitment
Apparently most mounts move the engine so that you'll have to mod the trans mount. However one of the vetteforum sponsors is coming out with a mount that keeps the engine in the stock location and incorporates a Z bar connection. That way you can use your current clutch setup and bellhousing.
As for F body vs the vette LS1. The alternator mount on either will work, but I have seen posts on F body alternator require slight mods due to a very close fit to the frame. The higher vette doesn't seem to causde a problem.
The oil pan rom the f body definitely works. Although I have not seen any issues with the vette pan either.
I'm doing the same swap in my 68.
Gary
I used the brackets and setup from the F-body... and moved the motor about 1 inch forward. Also had to make changes to the steering rack... with spacers...
I used the TH350 so I can't help with the tanny... but you will have to mod your cross member.
can't help with INtake... I run a HOLLEY CARB !!! LOL
I'm curious about your comment on f body accessories fitting better. I'm looking at an LS1 or 2 for my 68 vette. I'll only need the water pump and alternator. Did you run into any clearance issues with the vette high mounted alternator?
If Vette accessories will work for what you're doing, there will probably be significantly less frustration sourcing parts if you go that route. EVERYONE (& their dog) is looking for F-body accessories...
I'm liking the headers. What the price?
But a question on the motor mounts. Do they leave the engine/transmission in the stock location? Everyone I've spoke with said prety much all LS/SBC adapters move the engine forward 1-2". I'm using the stock Muncie transmission and dont want to have to modify the driveshaft or trans crossmember.
Gary
Are you planning on running a hydraulic throwout bearing? The stock cross shaft will not fit with out some major modifications
I have the headers in natural finish for 250.00
As for cluch, If I cant get the Z bar pivot mount (SD parts) that bolts to the bell housing to work, then I'll go with a hydraulic throwout bearing.
Also there's another vendor that says they're in the process of producing a combo motor mount/Z bar pivot mount. But ot release timeframe yet.
Gary
