Curb Weight for your finished LSx Conversion? Any 92+ RX7, 3rd or 2nd Gen Miatas,etc?
With me in it at 195lbs.(2785)
LF – 769, center to fender 12 2/8
RF – 740, c to f 12.0
LR – 654, c to f 12 6/8
RR – 622, c to f 12 4/8
X=50.0 – BETTER THAN STOCK MIATA
Left is 51% - BETTER THAN STOCK MIATA
Rear is 45.8% - WORSE BY 1% THAN STOCK MIATA
These are the weights of my 90 model. ls1/t56.irs8.8/10pt cage.
I'm thinking of selling this car and building another one for the track only, lexan, cut up, etc. This one is a little too nice. Let me know if you need any info.
Here's how it was distributed when the car was stock. I weighed it first so I knew how to best place the weight as it went back together.
With me in it at 195lbs.(2358)
LF – 653
RF – 600
LR – 575
RR – 529
X=50.12%
L=52.07%
R=46.82%
I hope this helps.
LF – 653
RF – 600
LR – 575
RR – 529
X=50.12%
L=52.07%
R=46.82%
I hope this helps.
I dont have any numbers yet...but im guessing its gonna be well under 2800lbs. More around 2650-2700 without me in the car. I have no AC,ABS,really light seats/wheels, no PS and its an R1 which is lighter than the touring to start out with.
i had a 98 t/a down to 2967 w/o me and it still had a steel hood and stock k member, steel gas tank ect....the f/r wasnt too bad on it either, i think it was 51/49.........you could take a notch mustang and get it down to 2500lbs with a lsx.......i thought the miatas would be lighter than that.....
My rather portly 1935 Ford Tudor smashes the scales to the tune of 3300 pounds. Of course it's all steel and has a fully boxed Fatman frame. The interesting thing is that my LS1 and 4L60E is 25 lbs less than the original all iron 100 hp 239 inch flathead V-8 and three speed trans!!
Robert@SPEEDSOUTH: Try a '99 Miata for your next build, they have better suspension and a much better weight distribution in stock form. We just built one and ended up with 51% front 50.5% cross and 50% side to side.
I have a '85 Celica GTS hatch and with full interior, spare tire, and half a tank of gas it weighed in at 2900lbs. It is now 54% front weight but cross weights are almost perfect (49.7%). I gained 120lbs over the stock 22RE, now it's time to see where I can lose some weight in the front end.
