AC pressure sensor question
Old Jul 15, 2017 | 09:42 AM
TipsyMcStagger's Avatar
Originally Posted by rao
The hard part is that the pressure sensor needs a "special" port, which I have only found at Docs Blocks, it is their part number AC0146. http://www.docsblocks.com/proddetail.asp?prod=AC0146
Old thread BUMP
Docs Blocks is no longer around.
Anyone got a source for the AC0146 port?
Tipsy
EDIT: Is this the same as AC0146?
Old Jul 15, 2017 | 10:52 AM
Originally Posted by TipsyMcStagger
Old thread BUMP
Tipsy
Got this reply on another forum. Great info!
That'll work. Here are other sources
http://www.apairinc.com/shopping/pro...=129630&c=4384
http://www.autoacfittings.com/R134a-...minum-4063.htm
Also available in steel if needed
http://www.autoacfittings.com/R134a-...-Port-4166.htm
Old Apr 2, 2018 | 07:50 PM
96gt4.6's Avatar
Bump. Needing some help on this one.
I need a #6 beadlock AC hose fitting that has a M10 service port for the pressure sensor....and i'm not having much luck.
I too am running a vintage air kit, and all the lines from the condenser to the vintage air unit are #6, which is where I plan to put the pressure switch.
I suppose I could put it in the compressor discharge line as well which is a #8?
Any help appreciated!
Old Apr 3, 2018 | 08:48 AM
This? or this?
