carb 5.3 for 72 nova, help ???'s
Old Jan 12, 2008 | 06:53 PM
novabob72's Avatar
Default carb 5.3 for 72 nova, help ???'s
wanna do a 5.3 swap in my 72
So far, I want to use
Moroso pan PN# 20140
Motor mount adapter plates for stock sbc motor mounts
edelbrock RPM manifold w/ignition control box
670 holley street avenger (already own, hoping to reuse) since the ignition system is distributor-less, what would i run the vac. secondary from?
stock 02+ LS6 cam
stock LS1 exhaust manifolds
Anyone see any problems here??????
Car has a fresh th350, 2000-2200 stall
3.31 gears, 235/60/R15 (26.1" tall) rear tire
Car is set up as a DD, would see use on wed. night at the local track just for fun
Old Jan 12, 2008 | 07:04 PM
RAGENZ28's Avatar
Drill and tap the manifold for a vacuum fitting?
Old Jan 12, 2008 | 07:19 PM
novabob72's Avatar
^^^^that is what i was thinking, but will it work, the only way i have ever seen it done is to a vac canister on the dist.
Old Jan 12, 2008 | 08:07 PM
LS1MCSS's Avatar
Don't use the timing box sold by Edelbrock. Use the one sold by MSD. The Edelbrock box uses pills to change the timing but the MSD can be changed with a laptop and their free software. You can get a much better timing curve that way.
Old Jan 12, 2008 | 08:10 PM
novabob72's Avatar
thanks for the reply, will do
