i need a power steering pump!!!!!
Old Jan 15, 2008 | 02:42 PM
leonpiper69's Avatar
Default i need a power steering pump!!!!!
i know this isnt the for sale section but i havent had one reply over there
https://ls1tech.com/forums/parts-wanted/844424-need-power-steering-pump.html
and i figured i would have better luck over here.
i need one because it appears that you cant run the serp belt without the pump?
Old Jan 15, 2008 | 07:12 PM
TomH's Avatar
I have one from an '06 LQ9 w/~500mi on it.
Make me an offer.
Old Jan 15, 2008 | 07:34 PM
jomomma's Avatar
i have a procharged ls1 video on here of my truck running without the power steering pump. it used to have one, but the procharger threw the belt and it sawed into the reservoir and killed the pump. ive been running it now for a couple weeks and have`nt had any problems. the belt comes extremly close,but does`nt touch the bracket bolts.
Old Jan 15, 2008 | 10:13 PM
LS1Cobra's Avatar
You are in luck. I just put one on ebay. Please shoot me an email with a reasonable offer and it's yours.
Vinh
Old Jan 15, 2008 | 11:38 PM
Make me an offer.
im not sure if those are the same?
Old Jan 15, 2008 | 11:39 PM
mine will deffinatley hit. i test fit the belt and it was touching a lot
Old Jan 16, 2008 | 05:13 AM
67pete's Avatar
Are you running P/S ?
I just bought an Idler pulley from NAPA and in process of adapting it to the engine in place of the pump.
Old Jan 16, 2008 | 03:52 PM
i did put a power box on it (i still have the manual one) and was not sure what to do yet. right now i just want to be able to run it, i'll worry about the power steering later on.
if you come up with any way of useing an idler let me know.
Old Jan 16, 2008 | 04:59 PM
Rodder's Avatar
if you just want to run it briefly, leave the belt off...
Old Jan 16, 2008 | 08:23 PM
then i am worried about over heating, im trying to let it run so the comp can relearn (it doesnt like to idle on its own yet) i havent run it more than like 10 seconds at a time to be safe
Old Jan 17, 2008 | 09:16 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
I think we are having spacers made right now to do the idler pulley setup. If not, we could make a bracket for you. We do it on the dyno all the time.
Old Jan 17, 2008 | 12:41 PM
jomomma's Avatar
is the idler pulley still in place in between the crank and alt ?
Old Jan 17, 2008 | 01:45 PM
yeah it is ,but i think i have one ( a pump) on its way.
