wiring questions
Oil Pressure: Optional but recomended
Clutch Anticipate Switch Signal: uncertain
IGN Power for TCC Stop Lamp Switch: Optional but recomended
TCC/Cruse Brake Switch: Optional but recomended (Paired with above)
Ground
PNP Switch Signal: Optional
Low Coolant Indicator: Optional
VSS Output: Optional but recomended
5V Feed (Fuel tank pressure): Optional
MIL Control: Optional but recomended
EVAP Canister Vent Valve Control: Optional
Theft Detterent Fuel Enable: Required
A/C Request: Optional
Fuel Ground: Optional depending on how your fueling is setup
Fuel Tank Pressure: Optional
Fuel Level Input: Optional
Serial Data (Class 2): Optional but recomended
Hot in Run and Start (IGN/INJ Bank 1 15A): Required
A/C Clutch Relay Control: Optional
A/C Clutch Status: Optional
TPS +5v to TCS: Optional
TPS signal to TCS: Optional
with IGN 1 Relay Engaged (Tranny/EGR 15A): Required
Cooling Fan 2 and 3 Relay Control: Optional but HIGHLY recomended
Cooling Fan 1 Relay Control: Optional but HIGHLY recomended
TPS sensor low to TCS: Optional
Low Coolant Sensor: Optional
Hot in Run and Start (IGN/INJ Bank 2 15A): Required
Air Pump Relay Control: Optional
Fuel Pump Relay Control: Required most likely
Ignition Positive Voltage for PCM: Required
Battery Positive Voltage for PCM: Required
Ground:
TCS Spark Retard Signal to Brake Control Module: Optional
Hot with IGN 1 Relay Engaged (TCC Stop Lamp Switch/MAF/O2 20A): Required
Cruise Control Inhibit: Optional
Cruise Engaged Signal: Optional
Tach out to Brake Control Module: Optional (Re-use for dash tach)
AIR Solenoid Relay Control: Optional
That's my oppinion on things.. Does it help?
TCS is traction control system.
You do need the fuel enable circuit from the VATS system. You can pick up a bypass unit I believe that will trick the PCM into thinking everythign is ok. Without this hooked up though, you'll never get injector pulses.
I run the stock LS1 alternator which is 1 wire as well I believe.. a brown one which is used for voltage regulation. I'm not sure if you will have problems or not.
No problems at all with !AC, !PS. In my conversion, I run no PS, AC, EVAP, EGR, AIR, ABS, TCS, Traction Control,... I only run the necessities.
It's weight reduction to me. Trending Topics
Please read entire thread! Thanks, Glenn
in my sig is a link to my web page, then in the left click the V8 swap link.. and there is a link to the pinouts on that page.
2001 LS1 5.7L with 4L60E A4 Transmission
Blue connector....
23 - Low Reference
25 - HO2S Low Signal Bank 2 Sensor 2
28 - HO2S Low Signal Bank 1 Sensor 2
32 - CPP Switch Signal ? what is CPP?
65 - HO2S High Signal Bank 2 Sensor 2
68 - HO2S High Signal Bank 1 Sensor 2
70 - Oil Level Switch Signal
Red Connector....
4 - Air Injection Reaction Solenoid Relay - Coil - Control
13 - Cruise Control Engage Signal
34 - Evaporative Canister Purge Solenoid Control
36 - AIR Pump Relay Control
37 - Cruise Control Inhibit Signal
45 - Evaporative Canister Vent Solenoid Control
46 - MIL Control ? what does MIL stand for?
53 - Ignition Retard Signal
54 - Fuel Level Sensor Signal
64- Fuel Tank Pressure Sensor Signal
I paid good money for this conversion. Everyone else gets this data for free.
MIL is the check engine light. (Malfunction Indication Lamp or somthing to that effect)
CCP: Clutch Position (maybe, just guessing)
I have an M6, so there's a few that are going to be different. Do you have EGR, AIR, or TCS hooked up?
Thanks alot,
Matt
I will be posting further details later.
