ls1 to old school 350
oopps, well, i'm old and of the opinion that the last good camaro was '69.
(oh...... i'm gonna burn in hell for that one
it just wouldnt make sense to me to do what your trying to do. but i guess if you dont like good gas mileage and lots of power all in one well then sell the ls1. you could always put a carb on the ls1 is your scared of the fuel injection.
sounds like you have a lot of sbc stuff you should sell that CRAP and use the money from that on the ls1.
unless the car is going to be a race car ONLY it would make me sick to see a sbc in a ls1 car
but you said you were going to drive it around like a street car. idk do what you want really but it just doesnt make since I'm going carbed for the same reason of not being too keen on fuel injection but absolutely crazy for a <400lb engine, 15 degree heads, 6 bolt mains, 6 speed that allows me to run 4.56s and 30" slicks and daily drive it without spinning 4,000rpm on the highway, and a distributorless 8 coil igniton. intake is $285, MSD ignition that runs off the stock coils and cam/crank sensors with fully adjustable timing based on the MAP sensor and is only like $312, Old school smell with new style power, reliability, weight savings and just all around bad assness.
Leave the LS1 car alone. Put the gen1 in something older. It's just plain backward unless it is a pure race car. Even then I couldn't see it to be honest.
If you want to sell the LS1 to make money...throw a junkyard 5.3 back in it. It would be easier/faster/cheaper.
lt1 motor mounts and headers are the same as sbc, so if you use lt1 stuff it should drop right in.
