4.8 to 5.3
Old Jan 21, 2008 | 08:10 AM
neals98's Avatar
Default 4.8 to 5.3
Will i be able to just put a 5.3 in my truck with out having to change anything. I am going to use my coil packs,intake. The motors are out of 2001 models the only diff between the two was the motors. The truck with the 5.3 was totaled but motor is good..............THANKS
Old Jan 21, 2008 | 08:15 AM
jkwalkercchs's Avatar
if im not mistaken u will need a tune because the 5.3 is different
do u have the 5.3 pcm? if so use it
if u have it out go ahead and do a little work to it just my opinion
Old Feb 19, 2008 | 08:20 PM
mjacus's Avatar
2003 Silverado
How involved is it to swap a 2003 4.8 to a 2005 6.0 LQ9 without a wiring harness from doner? And if L60E tranny to L80E is a big job. Thanks!
Old Feb 19, 2008 | 10:52 PM
G-Body's Avatar
sawzall wielding director
everything between the 4.8 and 6.0 will bolt up. I don`t know what will have to be changed to make the 80e fit, probably the driveshaft length and trans mount.
To make the 80e work you will have to change the positions of a couple wires and add a couple wires. You will also have to have the PCM re-tuned to control the 80e and 6.0l
Old Feb 20, 2008 | 09:50 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
I can help you with the tuning.
