Fuel line questions
Old Jan 29, 2008 | 09:08 AM
95GreenZ28's Avatar
Default Fuel line questions
I need some help here guys I installed a ls1 into my 95 Z. I need to get the fuel hooked up so I can drive this car finally. I put a 99 vette filter/regulator where the stock filter goes. I have the line to the front connected already. I need help on how and what to run to the feed and return side from the tank to the filter/regulator. Anyone able to help me out here? Thanks in advance!
Old Jan 29, 2008 | 10:11 AM
LS1GMCTruck's Avatar
Default Well...
You have to have a return fuel port connection at your fuel tank. Connect this to the return nipple on the Vette regulator/filter. Its labeled on the regular, which is return & which is fuel supply(in).
Old Jan 29, 2008 | 10:47 AM
67rsss's Avatar
The 3/8 is the input to the filter/regulator and the 5/16 is the return to the tank.
Old Jan 29, 2008 | 11:37 AM
95GreenZ28's Avatar
I know which is which I am asking how do I connect my lt1 quick connect to the 3/8 vette regulator
Old Jan 29, 2008 | 11:55 AM
67rsss's Avatar
Good question. Wish I had the answer.
Old Jan 29, 2008 | 11:57 AM
95GreenZ28's Avatar
Thanks for looking though man!
Old Jan 29, 2008 | 03:57 PM
Shon Herron's Avatar
If it's routed to the tank, yep!
Old Jan 29, 2008 | 05:10 PM
95GreenZ28's Avatar
?? I am asking what type of fitting is needed to connect the two.
Old Jan 29, 2008 | 05:14 PM
LS1MCSS's Avatar
What type of connection, if any, does the original line have on it?
Old Jan 29, 2008 | 09:19 PM
if you are using the stock LT1 fuel rail connections on the filter/reg and trying to connect it to the stock plastic lines then you can get the part needed from Advance Auto. It's in the fuel repair section.
Old Jan 29, 2008 | 09:25 PM
95GreenZ28's Avatar
Thanks Shon
Old Feb 5, 2008 | 03:11 PM
AnniversaryZ28's Avatar
I think i am going this route for my swap, i am still waiting on an answer regarding it bolting to a stock intake.
http://cgi.ebay.com/ebaymotors/97-98...spagenameZWDVW
