Help!! LS7 first startup procedure??
Old Jan 29, 2008 | 09:28 AM
Wardrum's Avatar
Default Help!! LS7 first startup procedure??
Getting ready to fire my LS7 crate engine for the first time. Do any of you have a link to the procedure to follow for the LS7 with dry sump? Your help would be appreciated
Old Jan 29, 2008 | 09:56 AM
LS1GMCTruck's Avatar
Default Start-Up
I admit I do not know proper start-up procedure, if there is one at all, but I do know that, if you depress the pedal to the floor & hold it there during start-up, on any LS series engine, that the engine will crank only & not fire. This allows a prelube of sorts. I know this works, as I have done it. Hope this helps.
Old Jan 29, 2008 | 10:50 AM
XcYZb's Avatar
When I fired mine, I did as noted above, I simply turned it over by the starter without the ignition off. A pre-lube of sorts. I didn't use the WOT trick, though. I just supplied 12V to the solenoid.
Old Jan 29, 2008 | 01:21 PM
Rodder's Avatar
another way is to pull your injector fuses
John B's Avatar
Moderator
Ditto...just cranked it for a few seconds then I connected the coil pack wire harnesses.
Old Jan 29, 2008 | 02:09 PM
Rodder's Avatar
You don't want to wet down the plugs. Leaving the ignition firing is fine, it's fuel that you want to cut off.
Old Jan 30, 2008 | 01:16 PM
John B's Avatar
Moderator
Good point to clarify! Having fuel wash the cylinders walls down is the worst thing you can do! I had my fuel system drained back to the fuel filter so when I cranked mine I knew that the fuel wouldn't get to the motor before I stopped cranking.
Old Jan 30, 2008 | 02:53 PM
Oscar Will's Avatar
I always pre-lube everything on the engine stand. It'll work in the chassis also. When an engine is properly pre-lubed the oil galleys are full, the lifters are bled & full, it's the best way to make sure nothing is dry when first started.
Old Jan 30, 2008 | 04:56 PM
XcYZb's Avatar
Agreed. That's why I didn't power up the ECM when I was cranking mine, just supplied 12V to the starter.
Old Jan 31, 2008 | 07:53 AM
Default Actually...
The best, money is no object, means to make your engine last with pre-lubing, is a fully installed pre-lube, air pressurized system. Each & every time you start the engine, its prelubed by hitting a switch prior. I've installed these on offshore race & pleasure boats with big power. Dry start-ups, which all of us have, are said to be an engines worst enemy over time.
Old Jan 31, 2008 | 10:27 AM
c5racr1's Avatar
put the key in and start it it has allready been started and run at wixom assembly plant.
Old Jan 31, 2008 | 12:05 PM
Wardrum's Avatar
First, thanks for the info guys.
I planned to be shut down the fuel to prevent wash down but good point to remind others of. Pumping oil from the dry sump tank into the engine is going to take some time. Any body have any idea how long? The supply outlet from the tank is above the oil pan fittings so there will be some gravity supply action.
Another question I have is what oil to use for startup. Factory recommends 5W30 synthetic for normal operation but their start-up and break-in procedure says to use none-synthetic until after 2nd oil change @ 500 miles. Is that what you are doing?
c5racr1, not sure that sticking the key in and starting it is a good idea. My engine has been sitting for awhile during the build and whatever oil Wixom used has probably pretty well drained down completely.
Old Jan 31, 2008 | 02:27 PM
John B's Avatar
Moderator
The reality is....the motor is already broken in on the Dyno at Wixom as C5racr1 points out.
Old Jan 31, 2008 | 08:08 PM
Wardrum's Avatar
John B, so put 5W30 synthetic oil in right away and start it after a short pre-lube?? Sure would be easier than changing twice in first 500 miles.
c5racr1, my main concern with your comment was that I didn't think starting it immediately would pre-lube it enough before start-up. It sat idle for close to a year while I worked on the rest of the car.
Old Feb 1, 2008 | 09:58 AM
Default I agree...
Just start that baby up. No worries mon.
Old Feb 1, 2008 | 12:13 PM
Stu Cool's Avatar
Wardrum, Really glad to hear you are getting this close. Will you have it at Hot August Nights this year? Looking forward to seeing it.
Pat
Old Feb 1, 2008 | 12:33 PM
Chris442's Avatar
Needs to finish car
When I started mine, I just cranked it and started it. Took a while cranking to get fuel up to the rails, as the E38 doesn't have the pump set to prime the same way as the older computers. More than likely that got enough oil moving around. It was 4 am when we first started it, so prelubing didn't really cross my mind. I also used synthetic oil from the start, figuring it had some run time in Wixom, and these things come in 'vettes with synthetic from the start.
If you're using the stock computer, don't be concerned if it makes backfiring sounds at first, since the crank sensor is not sinked up it could be firing the plugs 180* off. When it starts, be prepared for one seriously fast ride.
I'm with Pat, too; I want to see this thing. It should be a seriously nice car.
Old Feb 1, 2008 | 03:24 PM
John B's Avatar
Moderator
That's what you received it with (empty of course)!
Old Feb 1, 2008 | 10:51 PM
Wardrum's Avatar
Pat
I'm hoping so. My wife's class reunion is that weekend so we are having an on-going family discussion about it.
Old Feb 1, 2008 | 11:07 PM
Wardrum's Avatar
OK, 5W30 synthetic it is.....and away we go
