my swap is alive!
Old Feb 1, 2008 | 03:34 PM
DCx's Avatar
DCx
Default my swap is alive!
my carb ls1 swap is alive!
http://www.youtube.com/watch?v=YQn5_6YU7lc
Old Feb 1, 2008 | 03:53 PM
MikeG's Avatar
Sounds wicked man, congrats on a fine swap.
Old Feb 1, 2008 | 03:56 PM
C Murda's Avatar
thats sick man my next project is a 1st gen ls2 swap...but thats a far way down the road as of now
Old Feb 1, 2008 | 04:30 PM
JZHeyde's Avatar
Sounds awesome, that almost makes it ok that we got 12" of snow last night in chicago! Congrats on the project!
Old Feb 1, 2008 | 05:47 PM
6D9's Avatar
6D9
Sounds killer! Give us some specs!
Old Feb 1, 2008 | 06:04 PM
Rodder's Avatar
Congrats!
Old Feb 1, 2008 | 06:21 PM
leonpiper69's Avatar
it feels good when it finally runs hugh? congrats man, now if i can get mine to idle......
Old Feb 1, 2008 | 06:35 PM
6L.IROC-Z's Avatar
congrats
Old Feb 1, 2008 | 10:35 PM
Qwkss's Avatar
Awesome!
Old Feb 3, 2008 | 12:58 AM
DCx's Avatar
DCx
i got the alternator charging and rigged up the exhaust on it today. it sounds very tame to me.
ill post more vids with the exhaust tomorrow.
Old Feb 3, 2008 | 12:25 PM
a10beav's Avatar
Good job!
Old Feb 3, 2008 | 03:53 PM
CobraB8_ZO6's Avatar
That is freakin awesome!
Old Feb 3, 2008 | 05:26 PM
bgblockelcamino's Avatar
congrats
Old Mar 6, 2008 | 12:22 AM
DCx's Avatar
DCx
sorry i dont have anymore videos to post but i do have some news and some pics.
the good news is all my wiring is done and everything works! the fan turns on at 200* and off at 190*. i have the second wired to the battery and a toggle switch for double cooling. the alternator charges just fine and i have good fuel pressure.
the bad news is i test drove the car today and it looks like i need to pull the whole rig out! 3rd gear is toast and grinds like a bitch. all the other gears work just fine. looks like i need a rebuild...
here are some pics to pass the time.
Old Mar 6, 2008 | 07:33 AM
RacnJsn95's Avatar
Are you running the Edelbrock, or MSD timing controller? You have it mounted in the car?
Old Mar 6, 2008 | 02:23 PM
DCx's Avatar
DCx
im running the msd. i took all 16 pins out of the connector and fed them through a small 1/2 inch hole in the fire wall. i plugged them all back in and mounted the box to the inside of the firewall with Velcro
Old Mar 6, 2008 | 03:09 PM
72chevy2's Avatar
What trans are you running?
I'm looking to do just what you did!
Any helpful advice you could give? More importantly information on motor mounts and the ignition system... Mine will be going into a 72 Nova so actually what headers did you go with?
Old Mar 6, 2008 | 05:33 PM
DCx's Avatar
DCx
i used carshop plates, factory rubber mounts, and hooker headers. when i yank the engine out again to have the trans looked at i think im going to swap the oil pan. the autokraft pans sump is wide and the tie rods hit it at full lock.
Old Mar 7, 2008 | 10:18 AM
Rodder's Avatar
The current pictures on autocraft's website look like they beveled the corners of the sump and inch or so to fix the tie rod clearance problem. My older Autokraft pan has a nice tierod shaped dent in it right now..
