S10,370,T56,twin GTK550's
Old 10-20-2008, 08:33 AM
99SLOWC5's Avatar
It fell off the list of priorities as summer rolled around. cold weather is coming and the truck will be making progress soon.!!! Should be moving on its own come spring time.
JEFF
Old 02-24-2009, 09:36 PM
99SLOWC5's Avatar
Boy have things changed since the last time I posted
11/23/2008
Well, I'm back at the truck. We put the k-bosh on the turbo's right now. My buddy and I want to just get the truck running first. Be able to drive it this coming summer and get all the bugs worked out. We still have alot of work to do to get the bastard out on the road.
We purchased a 12.0:1 comp 370 from a friend that was spraying a 300 direct port shot on it, in a 3800lb firebird running 9.8x@14x. NA on the nitrous tune it went 11.4 with a nitrous converter. The engine is a iron 6.0L block bored, stock crank, eagle rods, diamond pistons. patriot perf stage 3 heads. Close to 500 at the wheels
So we will be switching to a NA YANK converter and running the car NA, with a turbo 400 behind it. Hoping to purchase a set of Current Perf headers once I see they have started shipping.
I picked up a 8.8 ford rearend that we'll be installing right away. Have the driveshaft already. Right now I've been boxing in the frame just for added strength, The engine oil pan was very close to the cross member so I have modified that also.
Thats the updates and more should come, The turbo is still in the minds just waiting on getting a running truck first.
1/14/2009
Finally received my motor plates, Waiting on the CP long tubes to set the engine up with the motor plates. I'm exciting to hopefully get this thing moving along more....
1/31/2009
Finally some progress!! We got the headers mid week. So I got those installed and massaged the block and bell housing in a few areas to provide ample clearance. fit the engine and headers onto the frame and got the cab on with clearance there too. Cut the motor plates and got the fitted. Shot over to work and machined the plates to clean up the cuts and remove the excess material that was not needed :thumbsup Tommorow I'm hoping to weld my brackets to the frame and mount the motor plates to the frame.
2/10/2009
Started ordering more parts, and finishing most the Fab work. I made my own "NEW" Trans cross memeber. Needed it changed now that we have the Long tubes installed and see that they would have hit the Crossmember. I dont have pictures yet of that. I redrilled my 8.8 rear end at work for a chevy bolt pattern. We DID not narrow our 8.8 rear-end. Tonight we tossed my buddies FIKSE's on and they seem to fit perfect 17x11 with 315/35-17. So the Drag package we buy should also fit perfect. Which to find out is great news being I didn't narrow the rearend. Picked up a EdelBrock vic jr intake and elbow. Mounted the Transcooler in the back like BLACKX, Loved the idea. Cut the hole in the bed for the fuel cell. The fuel system should be ordered this week. It seems never ending but its fun To make progress. More to come. Thanks for looking and the comments
the way the engine got mounted and angled has allowed for perfect clearance for the steering shaft. That was a great feeling. I didn't check the clearance until after the motor plates were finally installed
2/11/2009
Shots of the trans cross member I made to add clearance for the exhaust. The brace farther back was for the mount for the 2 piece driveshaft. Now clearance for the the single driveshaft:thumbsup
2/21/2009
Well more parts are still coming in, Hopefully tomorrow I'll start and finish the driveshaft loop. Kyle got the 90mm TB, injectors, flywheel, plug wires in this week. With the TB on we were able to shorten the length of the cable to make it look a little more professional and cleaner. I then made a few parts at work to make the stock cable still work. We also pulled the carpet, seats, and rollbar out of the truck, cleaned the interior up and tossed some dynamat on the floor where the exhaust will be. Still need a few pieces to finish the whole floor.
Fuel system shipped friday so I'm excited to get that in and start plumbing that bastard!! I'm sure I'll post pictures:thumbsup
2/24/2009
got another item today. Hopefully by the end of the week, the converter will be in along with the everything else for the engine and trans so that its in for the last time... fingers crossed
Hopefully with everyone looking at this people might see things I've over looked.
JEFF SMITH
Old 02-24-2009, 09:56 PM
Rick Speed's Avatar
Looks pretty sweet. Love the wheels!
Old 02-24-2009, 10:35 PM
luckyhenriksen's Avatar
X2 On the wheels. Those wide tires look sickkk
Old 02-28-2009, 04:41 PM
99SLOWC5's Avatar
PROGRESS, everyone likes progress. Kyles turn to work, wiring comes next
Old 02-28-2009, 07:01 PM
sultan(ZR-1)KSA's Avatar
i think this thing is going to be awsome good luck on the built
Old 03-02-2009, 10:40 PM
99SLOWC5's Avatar
Picked up some gauges from my buddy Jeff @fuel Systems, Got me a killer deal on these
Just waiting on my harness from Current Perf, and my fuel system from NASTY PERFORMANCE
JEFF
Old 03-04-2009, 10:11 PM
99SLOWC5's Avatar
Like to thanks NATE @NASTY PERFORMANCE for the Fuel system. Now i just need to find where to mount everything. Should be enough pump to support the trucks needs:thumbsup
MagnaFuel 750pro tuner pump
75micron filter inlet
25 micron filter outlet
AN-10 feed line
feed both rails to a Magnafuel adj. boost reference reg.
AN-8 return
Engine wiring harness has shipped, hopefully it will show up by this weekend
JEFF
Old 03-04-2009, 10:28 PM
patriotformula's Avatar
Great looking project... Looks like you are doing things with a little TLC and time and not just thrashing stuff together... Always good to see people taking pride!
Old 03-04-2009, 11:02 PM
99SLOWC5's Avatar
thanks for the compliments
Old 03-05-2009, 01:49 PM
Black X's Avatar
Looking Really good bro. Cant wait to see how it turns out!
Old 03-05-2009, 02:15 PM
  #32
oct03gto's Avatar
Is there any way on getting some info on those Fisk wheels?
Nice project. Wish I hit the lotto and could finish mine.
Old 03-05-2009, 02:21 PM
  #33
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Damn, this should be crazy when its done! and I thought my 240 was going to be fun to drive!
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 03-07-2009, 12:42 AM
  #34
97 Z Me Go's Avatar
They are build for camaro backspacing. They are 17x11s. Fikse never sent me any spec sheet on them.
Old 03-07-2009, 06:40 AM
  #35
dogger's Avatar
hey one think you missed. THOSE FISKE WHEELS LOOK REALY GOOD ON THAT TRUCK. never seen them on anything but a fbody in that style but they look like they work nice with the truck.
Old 03-07-2009, 07:20 AM
  #36
LS1 SPEED's Avatar
looking good and boy that truck should be fun
Old 03-07-2009, 09:27 AM
  #37
99SLOWC5's Avatar
Thanks for the kind words guys.
Worked on the dash at work lastnight and got the gauges all laid out. We got our engine harness and are in the process of wiring and getting ready to turn the key
JEFF
Old 03-11-2009, 08:29 PM
  #38
97 Z Me Go's Avatar
I like to call this one "crank no start"! Theres no coils or fuel on it yet Just a couple more things to do!
Old 03-28-2009, 01:02 AM
  #39
99SLOWC5's Avatar
Well the bastard is alive, it starts and runs. Gauges worked fuel pump works, Just need to tune the bastard hopefully. Doesn't want to run very much right now. But I'm sure Tom will be able to iron that out, Being he tuned this engine once before.
Short little video
JEFF
Old 04-01-2009, 12:30 AM
  #40
97 Z Me Go's Avatar
Well after getting bummed out and wondering why the hell it would not run off the pcm out of my car being it has 42# injectors. Just always remember the computer is smarter than you. Had to turn the vats off!
Something to get excited about now. Im sure it will get all buttoned up alot faster now!
Quick Reply: S10,370,T56,twin GTK550's
