Aftermarket Fuel Rail Plumbing
I was wondering what the correct setup is for plumbing aftermarket fuel rails. I have mine setup, but I know they are not correct. Can anyone chime in & help me out!? Thanks!
It'll run fine the way you have it now, but ideally you'd connect from the outlet of the fuel filter to the rear of the passenger side fuel rail and plug off the port on the regulator that you currently have the feed line coming into. As you have it setup now if you start making a lot of power the injector at the dead end of the system (passenger rear) can be starved for fuel.
The best way is to run your feed line to a Y block, than the two lines to each fuel rail. Then plum the two fuel rails into the regulator, and run a return line back to the tank.
Ron
Ron
I have mine coming off the second filter(post pump) to the back of the driver side rail, then crossing over(well under the intake) then exiting out the back of the passenger side rail to the FPR then back to the tank...that ensures adequate fuel to all of the injectors. In a really high HP car a yblock setup would be more ideal, but ill never hit that kinda HP for my street car.
