starter / flexplate interchange?
Old Feb 16, 2008 | 09:34 PM
jimish's Avatar
Default starter / flexplate interchange?
My question is as such. C5 ls1 engine, I will be using a 5.3 truck bellhousing. Corvette flexplate is recessed, 5.3 flexplate is flat. Will corvette starter engage teeth on truck flywheel? If not, and I use a camaro type flexplate (recessed) will I have to alter the converter to lengthen the mounting lugs and crank snout? Or will a starter from a truck 5.3 bolt to the c5 block?
Old Feb 20, 2008 | 08:54 AM
jimish's Avatar
bump, anyone know about these bellhousings?
Old Feb 20, 2008 | 11:29 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
The only straight flexplate I have seen are on 6.0 engines that use the crank spacer. I could be wrong. All the starters end up in the same location it's just the flexplate that and spacer if needed that locates it correctly.
Old Feb 21, 2008 | 07:47 AM
jimish's Avatar
Thanks for the reply. I am going to get a truck bellhousing and bolt it up and see which flexplate I will need with my converter.
