VSS diagnostic code
Old Jul 15, 2003 | 07:55 AM
67ls1CamaroProject's Avatar
Default VSS diagnostic code
I finally purchased EASE scanner. Very nice tool. Anyway, the only code that I didn't really expect was the VSS code (P0500) I think. I have cut that wire and sent it to my Autometer speedo and then from the speedo I send it to the PCM just as directed by Autometer Tech. Could this be the cause? Anyone else get this code? My speedo works fine so the signal is there. I will try to freeze frame the code to see what else is happening. Maybe this is why my idle flutters when coming to a stop light? I have 4:56 gears and the PCM doesn't know it. Could this be a problem?
Old Jul 15, 2003 | 09:00 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: VSS diagnostic code
Monitor the data on your EASE while driving and see if the PCM is getting a speed signal. I suspect you have given up the PCM signal in order to have the speedo work.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
