misc harness info i've put together....
Old Feb 26, 2008 | 10:49 PM
busta9876's Avatar
Default misc harness info i've put together....
attached are some excel docs i've put together over some time...
PCM Differences.zip is a side by side PCM Pinout compairson of 2001 f-body, 1999 vortec truck & 2004 vortec truck. Highlighted in BOLD in the 99 vortec column are pins I remove from the 99-02 vortec truck harness for standalone setups.
Connector map vortec truck.zip Shows all connectors for standalone harness for 99-02. Each connector needed to run engine/trans is listed, with cavity #/letter of each connector, wire color, wire size, location in PCM connector it goes to, and description.
Mass Air Flow Sensors.zip is info I compiled on different sensors found in different vehicles. I listed typical applications, as well as how they are calibrated at certain frequencies.
Use this info however you feel, all info is from my own research in gm shop manuals and opening calibrations. There could be errors so double check..
File Type: zip
File Type: zip
File Type: zip
Old Feb 26, 2008 | 11:03 PM
busta9876's Avatar
found some other info I might add....
pictures of the connectors about 1" away from PCM on the vortec truck harnesses, C100, C152, C153, ...the excel file is the pinout and had highlighted what is used in a stand alone. Everything else can come out.
This pinot in particular is from a 2001 5.3 Truck...other years may be similar or may be the same...check wire color...pin location in pcm..etc...
again, use info as you like, double check if possible...
EDIT EDIT 3/9/2008
I've put together a bigger excel file that covers these connectors over all years of the Chevy Silverado 99 to 2006
open : C2 Underhood, c100, c152, c153.xls.zip
Attached Thumbnails misc harness info i've put together....-vortec_connectors.jpg   misc harness info i've put together....-c100.gif   misc harness info i've put together....-c152.gif   misc harness info i've put together....-c153.gif
File Type: zip
Old Feb 26, 2008 | 11:04 PM
Ellis Wun's Avatar
Thumbs up
Hey man, nice job.
Old Feb 26, 2008 | 11:07 PM
busta9876's Avatar
and one more final...this should finish ALL the info needed to convert a vortec truck harness to stand alone....
Wire Cavity , (# of wires), Color, Circuit #, description...see attached pic too.
CAVITY WIRE COLOR Circuit No. FUNCTION
B8 (2) ORN 440 BATTERY 12V+ TO PCM
C11 PNK 439 KEY 12V+ TO PCM
F2 (2) PNK 1020 KEY 12V+ TO PCM & TRANSMISSION SOLENOIDS
C10 (2) PNK 1039 KEY 12V+ TO INJECTORS 1 & 3
D10 (2) PNK 1039 KEY 12V+ TO INJECTORS 5 & 7
C12 (2) PNK 1239 KEY 12V+ TO INJECTORS 2 & 4
E7 (2) PNK 1239 KEY 12V+ TO INJECTORS 6 & 8
E12 PNK 1039 KEY 12V+ TO COILS 1,3,5,7
E6 PNK 1239 KEY 12V+ TO COILS 2,4,6,8
C4 PNK 239 KEY 12V+ TO MASS AIR-FLOW SENSOR
D8 (2) PNK 539 KEY 12V+ TO O2 SENSORS, BANK 1 & BANK 2 FRONT O2'S
D11 PPL 6 STARTER SOLENOID FEED, 12V+ DURING CRANK ONLY.
B7 DK GRN/WHT 465 FUEL PUMP RELAY FEED (PROVIDES 12V+ TO RELAY)
All the grounds needed will be in the engine harness. Should be 3 of them.
Rear of engine behind intake, should be two grounds. G103 & G104
Drivers side, below manifold is a ground. G102
DOUBLE CHECK THESE, THEY CHANGE YEAR TO YEAR...THIS IS FROM 2000 VORTEC TRUCK...PINK WIRES ARE ALWAYS 12V+ KEY POWER ON THIS CONNECTOR..JUST CHECK WHERE THEY RUN TO.
Attached Thumbnails misc harness info i've put together....-wire_junction_c2.jpg
Old Feb 27, 2008 | 11:01 AM
V8Rumble's Avatar
VERY cool, thanks a bunch!!
