LS2 Oil Pan Sensor
Old Feb 27, 2008 | 09:13 PM
Whickman's Avatar
Default LS2 Oil Pan Sensor
I just swapped a Corvette LS2 Oil Pan onto my '06 LS2. On the pan there are a couple of holes coming off just above the oil filter but I'm missing the adapter that goes on there. I did not have anything coming off of the trailblazer pan so I'm not quite sure what it is? It seems like it would be a oil pressure sender but I have one of those up on top. So, what is it? Do I need it? Is a part available to bypass it?
Also, is there a standard plug available to delete the Oil Level sensor?
It's going in a 72 4x4 Chevy truck if anyone cares.
Thanks,
Whit
Old Feb 27, 2008 | 09:21 PM
ls1nova71's Avatar
Corvettes have a oil temp sender there, and yes there is a block-off that most others have. Don't have a part number but I'm sure someone on here does.
