crank reluctor wheel
Old Feb 28, 2008 | 09:19 PM
classic gary's Avatar
Default crank reluctor wheel
anybody know where i could get one. I've got a crazy idea. a 24x would be the better of the two for me........
thanks, Gary
Old Feb 29, 2008 | 09:18 AM
Whickman's Avatar
The dealer or Scroggin Dickey will have it. If you are swapping from 58x to 24x you will also need a cam gear, cam sensor and crank sensor. I happen to have the last 3 items for sale since I just did the swap the other way (24x to 58x). The relector ring get's destroyed in the swap process so I don't have that.
Whit
Old Mar 1, 2008 | 07:58 PM
my "crazy idea" is adapting it to the front of a Gen 1 SBC, using an electronic dist with all but 1 teeth trimed off, and bolting the coils to the valve covers and run an MSD.
OK so, tell me I'm nuts, flame on............
Old Mar 5, 2008 | 11:04 PM
hum, nobody is telling me i'm nuts...................
then after all my Gen 1 stuff is used up I can continue with the LSx swap.
Old Mar 5, 2008 | 11:39 PM
Whickman's Avatar
It sounds like one of those ideas that sounded good when you started it. I think I've been down that path a few times. Good luck.
Old Mar 6, 2008 | 04:41 PM
Jaysz28's Avatar
Active Streak: 30 Days
Something along this line of thinking?
http://www.thirdgen.org/techboard/tp...-opinions.html
-jason
Old Mar 6, 2008 | 05:19 PM
Yes !!!
