64 Chevelle LS1 swap started
Old Mar 24, 2009 | 06:40 PM
  #41
oange ss's Avatar
Originally Posted by obfpd172
Found this when looking for motor mounts looks like they would work to me.
http://www.jegs.com/i/Trans+Dapt/969/4592/10002/-1
Is there a height difference between the short wide and the tall narrow then the motor half the frame half are togther.
cool, there is no height difference between the tall/narrow or short wide mounts, thank Stealth71 for that info.......i chose to use the tall/narrow becuase there is more isolating rubber in that mount setup than the short/wide mounts
Old Mar 31, 2009 | 12:11 PM
  #42
obfpd172's Avatar
Just got my t56 friday and worked on setting the pair into the chevelle. I was wondering if a cts pan would work. Would it give a little more room between the firewall and engine I want to leave the heater core in also to service the transmission, or will it hit the steering box. The F body pan makes it pretty tight to set in.
Old Apr 4, 2009 | 04:54 PM
  #43
obfpd172's Avatar
oange, I see you smoothed your firewall what are you doing for heat and ac if anything. Also do you have any measurements of hole you cut out in the firewall and trans tunnel
Old Apr 26, 2009 | 11:23 AM
  #44
OffspringZ28's Avatar
Looking good!
Subscribing...
Old Apr 26, 2009 | 12:30 PM
  #45
oange ss's Avatar
i dont have any experience with the CTS pan, sorry
will eventually use a Hot Rod Air setup for heat/air, but that will be later on down the road...didnt take any measurements,just took my time..cut,check fit,cut,check fit etc....
Old Apr 26, 2009 | 12:31 PM
  #46
oange ss's Avatar
Originally Posted by OffspringZ28
Looking good!
Subscribing...
thanx, i'll get it finished one of these days....
Old Apr 26, 2009 | 12:44 PM
  #47
84BuCkeTOfStEeL's Avatar
Can you go into detail on the front accessory you went with..did you go with oem gm or aftermarket thanks
Old Apr 26, 2009 | 01:04 PM
  #48
oange ss's Avatar
stock 98-02 F-Body
Old Dec 14, 2010 | 08:40 AM
  #49
oange ss's Avatar
finally got it painted, now just have to put the interior back together and finish Air Ride install
Old Dec 15, 2010 | 07:21 AM
  #50
98SuperchargedLs1's Avatar
looks good.. i cant wait to get mine back.. 65 chevelle ls2 built 4l80e single turbo, airride, 18/20s etc
