ls2 in notchback help
Old Mar 6, 2008 | 05:33 PM
dkbykesdk's Avatar
Default ls2 in notchback help
i have a 87 notchback which i got a ls2 motor for it, should i use the stock kmember? what headers are out there to work with this swap??
here is what it looks like i live in michigan an help would be awsome thanks
Old Mar 6, 2008 | 07:48 PM
jw33's Avatar
If you want a kit that bolts in setup for drag racing AJE and Kooks make the k-member/headers. Also try the search function. This is like the most played out question asked in the forum....
Old Mar 7, 2008 | 08:47 AM
djquik88's Avatar
Check out the link in my sig.
Old Mar 12, 2008 | 12:30 AM
dkbykesdk's Avatar
Default help
what i really wanna know is i have a 58x reluctor wheel do i need to changed it or can i keep it how it is?
Old Mar 12, 2008 | 04:26 PM
dkbykesdk's Avatar
hello
Old Mar 13, 2008 | 12:45 PM
Brains's Avatar
Yeah nobody has done this conversion before
On the 58x issue -- search is DEFINITELY your friend. You didn't provide enough information to answer you question either. The 58x works just as well as a 24x wheel, provided you get the PCM that matches
Old Mar 14, 2008 | 03:21 AM
dkbykesdk's Avatar
what if i carbed it??
do i have to change it. thanks
