Reverse lights stuck ON-4L60E
Old Mar 8, 2008 | 03:13 PM
BlackhawkSS's Avatar
Default Reverse lights stuck ON-4L60E
I just bought a 72' vette and one of the electrical issues is that the reverse lights remain on regardless of what gear Im in. It has a 4L60E, any insight on how I could fix this...other than taking the bulbs out?
Thanks
Old Mar 8, 2008 | 07:39 PM
ls1nova71's Avatar
It would depend on where your neutral safety/back up light switch is. Should be either on the shifter under console or on the steering column. Unless someone has put a range switch on the trans, but I wouldn't think so. You would have to check.
Old Mar 8, 2008 | 08:25 PM
Ok, so once I find out where the switch is, what needs to be done?
Old Mar 8, 2008 | 08:51 PM
ls1nova71's Avatar
It's been my experience that the small tab that moves the switch will break off, or at least half of it will. Pull it off and look at it, make sure its moving with the shifter.
Old Mar 9, 2008 | 11:34 AM
Pulled the console found no neutral/safety switch and for good reason. Original builder finally called back and he didnt install one. He was using the reverse lights as regualr brake lights to make 4 total. The next guy didnt know this and put reverse lights on with clear bulbs and thats what confused the hell out of me.
How hard would it be to put the neutral switch on, anybody done this and have pictures? If not Im just going to make it brake lights again lol.
Old Mar 9, 2008 | 06:16 PM
I found this but not sure how to mount it exactly, using the search I read to mount it on the shifter but not sure how?? Also unsure how to wire it up.
http://store.summitracing.com/partde...5&autoview=sku
