Edelbrock harness/cam sensor question
Old Mar 9, 2008 | 04:52 PM
Horsepwraddict's Avatar
Default Edelbrock harness/cam sensor question
Upon installing the harness for my carbed motor, I ran into a problem. Everything plugged in just fine untill i got to the cam sensor. The notch on the plug is on the wrong side, keeping it from plugging into the senor. Am i missing a harness that goes between them or something? Reason i ask is because the plug barely reaches the sensor, and honestly i think it will interfere with the carb linkage as it is now.
Old Mar 9, 2008 | 06:02 PM
jay_lt4's Avatar
i think you are plugging the wrong connector to the cam sensor, or you have the box mounted in the wrong direction, the main harness out of the box should come out to the passenger side of the engine
there is no harness that is close to the carb linkage if routed correctly
the box should mount on the intake, the main harness routes over to the pass side, 1 connector goes to the map sensor, 1 goes back along the pass side intake to the cam sensor, and 1 goes along the pass side intake and behind the pass cyl head and down to the crank sensor
then just the 2 coil harness connectors
Old Mar 9, 2008 | 06:06 PM
Thats how I have it run, the crank sensor even says 'crank' on it so i know its the right plug.
Old Mar 9, 2008 | 06:10 PM
jay_lt4's Avatar
i had that box on my 5.3 and my 6.0 engine and it plugged right into the cam sensor on both engines and was plenty long enough
what year is your 5.3
Old Mar 9, 2008 | 06:11 PM
its a 2000. Hold on, i'll grab a few pictures right now.
Old Mar 9, 2008 | 06:13 PM
im pulling it pretty good to get it this close to the sensor
the harness needs to be run way up high to be remotely close to the sensor.
Old Mar 9, 2008 | 06:20 PM
jay_lt4's Avatar
wrong connector , that is for the map sensor
Old Mar 9, 2008 | 06:25 PM
jay_lt4's Avatar
also why do you have paper style intake gaskets on the engine, that intake does not use flat gaskets gaskets, there are o-rings in the intake,,
Old Mar 9, 2008 | 06:26 PM
alright, well that makes sense...but i do have another question then lol. The map sensor you sent with the harness was plugged into the cam sensor plug...which has the notch on the wrong side for the map sensor plug on the harness. I had the factory sensor and i just tried it and it fit so it will work, im just wondering how you were using it like that?
Thanks for the help though, it would have taken me quite a while to figure it out.
Old Mar 9, 2008 | 06:28 PM
they were all torn up, i took em out. I know a couple people doing this, works fine, if it leaks i'll take em out and put the rubbers back in. Not a big deal.
Old Mar 9, 2008 | 06:29 PM
jay_lt4's Avatar
i probly just plugged in in for shipping without looking,, the gray connector goes to the map sensor the black one goes to the cam sensor
Old Mar 9, 2008 | 06:38 PM
thanks for your help.
