59cc Chamber, advice please...
I ran accross a set of lightly used Patriot LS6 stage II heads, and had to buy them. The price was too good.
Combustion Chamber: 59cc
Intake Runner: 227cc
Exhaust Runner: 70cc
Intake Valve: 2.055"
Exhaust Valve: 1.57"
Valve Guide Material: Manganese Bronze
Valve Job: 5-angle
They come with 317 springs instead of the originals, part of the good price. As most of you know, we still have a stock (or very close to it!) cam in the engine. Not really interested in changing the cam yet, looking to do that after the car has seen a dyno, but wondering how these heads will work out on the stock short block with a stock cam. We run 92 octane non-oxygenated fuel only. Patriot claims an 11:1 SCR when installed on an LS1, but it may be a hair higher than that since they also show a 10:1 for the stock LS1, which is really a 10.2:1.
The trans is at Six Speeds, and we are waiting on the new rear, so this might be a good time to putz with the engine a bit. Is this a good idea remembering that we will change cam later, (though nothing crazy), and that this is NOT a track car, but a fun toy to play with???
Finally, remembering that we are only looking to fall in the 360-400hp range, what would be a good streetable cam that would compliment these heads?
"Streetable" means something different to everyone, so it's pretty tough to imagine exactly what you really want
Did a quick search, here's a member's (z28ss4me) dyno sheet of such a cam with stock heads:
I expect you're down 30-40HP sucking hot air from the radiator.
