C5 torque tube shortening help.....
I have searched already,,,,,Can anyone help with shortening a C5 torque tube?
What type of aluminum is it? What welding rod should be used?
Any details that would help are appreciated..
any links or contacts (other than what you get when you search) that could help me out!...
I am shortening the tube to allow for my 4L80e to fit ..
Thanks for the help
Tom
Thanks for the help
Tom
You need a lathe to do this. any multy alloy compatiable welding rod can work.I belive the tube could be 6061 with cast 356 t4 housing ends. I talked with Mr Welch he had told me of your troubles. He siad to give him a call.
I am in the process of lengthening my torque tube. I cut my tube off and put each piece on the end mill and milled the weld off and got the old out. I bought 6061 T6 Aluminum tubing and Im taking to the welding shop to get it wired welded. You shoul be able to cut one end off (the end that goes to the bell housing of the motor) take it to a machine shop have them mill the weld to the tube brakes loose then slide the front piece back on and get it timed up. I set my up on a table and leveled it out and built jigs to keep them timed correctly. If you want to see any pictures jsut let me know.
68RS
If you could send pictures to tmo26@aol.com it would help me out..
Thanks
I had my guy cut the tube as you described ..but the rear part ( I have a bolt on rear bellhousing)
pictures please..
Tom
Thanks
pictures please..
Tom
Thank you,Joe
